[Progress Communities] [Progress OpenEdge ABL] Comment on Speed up automated testing in Azure DevOps Build
  • Thread starter Thread starter Harold-Jan Verlee
H
Harold-Jan Verlee
The recommendation is to consolidate all tests against the same test subject in a single test, but organized in multiple tabs (to represent the test scenarios you may have). Consequently, Corticon can execute against one test asset (deploy & compile once) and one single in-process instance of Corticon Server (used for scripted testing) saving considerable time.
