[progress Communities] [progress Openedge Abl] Comment On Installation Guide For Oedk:...
  • Thread starter Thread starter Mighty Quin
Mighty Quin
Hi kopatra, thank you very much for your response. Yes the log entries pasted in previous post is the entire content of oedk.log (found in the same directory as the installer). The installer is on the local machine. I do have Anti virus/spyware etc. running on both the machines that I tried to do the install on, so let me disabled that and see if the installation works. Also, would the pre-existing version of Java on the local machine affect the installation in anyway, or does Progress only look at the version bundled with the installer?
