arora_anjali
:shrug:
did anybody see this before ??
I AM USING ODBC CONNECTION using Progress OpendEdge 10.1A driver.
Following is my VB6 code wherein I try to update a decimal value with the value 1.3. It goes through fine without any errors but when I look at the the database - the value is now 130.00.
so if I try to put it a value of 12.34, the value that actually gets updated with is 1234.00
if I try to put it a value of 23, the value that actually gets updated with is 2300.00.
this happens only with Progress ver 10 database - the same code works well with Progress 9 database.
Public Sub testODBC()
Dim rsSnLoc As New ADODB.Recordset
Dim sql As String
' ' ---------- Create part_loc_sn records --------------------------
sql = "SELECT * FROM pub.part_loc_sn WHERE partno = 'BAC1676-67905' and serial_no = '1'"
rsSnLoc.CursorType = adOpenStatic
rsSnLoc.LockType = adLockOptimistic
rsSnLoc.Open sql, conn_parts, , , adCmdText
rsSnLoc!Qty_onhand = 1.3
rsSnLoc.Update
rsSnLoc.Close
Set rsSnLoc = Nothing
End Sub
Dim sql As String
rsSnLoc.Update
rsSnLoc.Close
End Sub
