Hi all,
We're trying to migrate from an unsupported PROTERMCAP entry and an older Terminal emulation program to a PROTERMCAP entry that is supported by progress (we've picked ansi/ansic - as that best fits all our current needs) and will be moving to PuTTy terminal emulation.
The problem we currently have is that sometimes the colors (which we have defined in the PROTERMCAP entry) do goofy things. For instance, we run our application code, and upon returning to the Progress Editor, the background color (which is blue) is now 2 shades of blue (darker where there is writting on the screen IE "run login", light blue for the rest). And even sometimes when calling a color code 18 - as defined in our protermcap it's black/white
COLOR 18 BLACK/WHITE=\E[30m\E[47m:\E[37m\E[40m:\) the background upon return to the editor is now BLACK except for where there is text - then it's blue.
Is the last "E[40m" the issue - in order to make sure that the background is blue upon return do we need to change this to 44m?
This is only an issue with our developement staff - as all our END USERS never get to the operating system or the progress editor.
HELP if anyone can, please.
TIA.
TIA.
