Problem with MERANT 3.50 32bit PROGRESS SQL92 ODBC Driver
Chris Kelleher
Administrator
Staff member
Hello all,
I have [attempted to] setup an ODBC connection to a PROGRESS 9.0B database
running on Windows NT. I am using Crystal Reports v7. Using Crystal, I can
connect to the databases fine and choose from a list of tables and fields
that I want to base my report on. Once I have selected my report criteria
and go to run (preview) the report, I get the following error message:
ODBC error: [MERANT][ODBC PROGRESS driver][PROGRESS]Access
denied(Authorisation failed)
.... with no associated error number.
The basic setup is as follows:
Server:
Windows NT Server 4 (SP4)
PROGRESS 9.0B (plus patch 018). Server started on database using TCP sockets
DLC/PROCFG/PROMSGS Env. variables setup correctly
PATH has DLC and DLC\BIN directories included
Client:
Windows NT Workstation 4 (SP4)
Merant 3.50 32bit PROGRESS SQL92 ODBC Driver
ODBC driver setup to connect directly to database using databases TCP port
number (not using OIB)
Logging on with valid user name and password (user has been setup with full
rights in database)
DLC/PROCFG/PROMSGS/IDLC/IPROMSGS/IPROCFG Env. variables setup correctly (not
sure whether the I.. vars are still required)
The connection is made successfully and it only falls over when trying to
fetch data. Any Ideas?
M. Gill
This indicates you forgot to GRANT the access rights to the
SQL tables.
>Server:
Those are needed to start the database server, they no longer
have anything to do with ODBC.
>Client:
>rights in database)
IDLC, etc. is no longer needed, this is a totally different driver.
PS You do realize this is an SDK product and not commercial, ie supported?
It's also the wrong list for this, you would want to be on the
SQL 92 list.
Geoff Crawford Phone: (973) 361 - 4224
Innovative Client Servers FAX: (973) 537 - 6946
75 Fleetwood Drive, Suite 200 Email: geoff@innov8cs.com
Rockaway NJ 07886 Web: http://www.innov8cs.com
Orange and Black Forever
