Problem with extractpl.bat / prolib.exe
Maviee
Hi,
I'm using Progress version 9.1e and I'm trying since days to extract the adecomm.pl and adeedit.pl files. Progress has a nice batch file on-board which should do this automatically.
Progress installation in Path L:\dlc91 , so I set the %DLC% variable to "L:\dlc91" also. Furthermore the extractpl suggests that you include the %DLC%/bin directory into the path. I also did this. Here are both commands:
set DLC= L:\dlc91
set PATH=%DLC%\bin
Typing "SET" in a DOS prompt I get the vars (I think correctly):
DLC=L:\dlc91
Path=L:\dlc91\bin
Alright I thought, everything is correct, lets try to unpack the files with the following line:
extractpl adeedit.pl AND extractpl adecomm.pl
The batch file creates the directoy but then prolib (which gets called by the batch file) tells me:
The DLC environment variable must contain a valid directory/path (11002).
I also tried the same thing in the proenv environment, but I still get the same error.
Did someone has the same problem or does anyone has a solution to my problem ?
Thanks in advance
Mav
This sounded pretty good, so I checked my registry entries. Every key in my registry has the value I assiged to the %DLC% variable. :(
Greetings
Mav
Lee Curzon said:
Check your DLC value in the registry, and in your ini file.
Needs to be exactly correct.
I notice your drive is L:.
Is it shared? There are issues with shared/mapped drives sometimes.
If so, try adding a backslash to the end of your DLC entries/variables.
Remember to backup before any registry/ini changes!
Try the environment variables first.
You are perfectly right. The L:\ drive is a shared drive on one of our DB servers. I tried one more backslash, but still without success. Is it possible to copy necessary files to my C:\ drive and start the unpacking from there ?
Greetings
Mav
You mean transfer the pls?
You can try, but it sounds like the problem is with the prolib executable itself.
There is a simple test: type the prolib command longhand (full pathname), including the full pathname of a pl you want to operate on (the pl can be anywhere - try it on your local drive).
If it works, then make a copy of the scripts, and replace the prolib commands with L:...\prolib (whatever), and try again.
Going back to the shared drive thing:
KB P86941 suggests a couple of other workarounds:
1. Upgrade to 10.0a :)
2. Share the drive at a higher level
(Quote)
1. If you share out the directory above the DLC this does not occur.
eg, sharing c:\program files\progress instead of c:\program
files\progress\dlc this error will not occur.
Incidentally, search the KB on error message 11002. That may give you a couple of other pointers.
If this doesn't work, and none else can help, you may need to talk to Tech Support (sorry!).
