Problem with Calling Stored Procedure
Hutch619
I am able to create the basic "Hello World" Stored Procedure just fine. The problem is when I try to call it.
This is what I've done.
Created Table
@echo true;
@autocommit true;
CREATE TABLE PUB.HelloWorld(
fld1 char(20)
COMMIT WORK;
Created Stored Procedure
@echo true;
@autocommit true;
CREATE PROCEDURE PUB.spHelloWorld ()
BEGIN
SQLIStatement Insert_HelloWorld = new SQLIStatement (
"INSERT INTO PUB.HelloWorld(fld1) values ('Hello World!')");
Insert_HelloWorld.execute();
END;
COMMIT WORK;
Call Stored Procedure
@echo true;
@autocommit true;
CALL PUB.spHelloWorld();
Commit;
This is the output I get back
=== Statement 1. ===
@echo true
Ok: Echo true. (8932);
=== Statement 2. ===
@autocommit true
Ok: AutoCommit true. (8932);
=== Statement 3. ===
=== SQL Exception 1 ===
SQLState=HY000
ErrorCode=-210022
[JDBC Progress Driver]:.
Errors 1.
=== Statement 4. ===
Commit;
Statements: 4; Updates 0; Rows 0; Errors: 1; Warnings: 0. (8926)
ANY IDEAS? :confused:
Maybe this helps:
KBP8029:
Status: Verified
FACT(s) (Environment):
Windows NT 32 Intel/Windows 2000
Progress 9.1D
Progress 9.1C
Progress 9.1B
SYMPTOM(s):
SQL-92 Stored Procedure and Trigger returns an error when executed.
SQL Exception:
SQLState=HY000
ErrorCode=-20211
Error -210022 when running SQL-92 stored procedure or trigger.
210022 DataDirect Technology Progress ODBC driver failed during
dynamic load of
Java dynamic library resend 126.
The SQL-92 Stored Procedure and Trigger compiled without errors.
CAUSE:
The shared library path has to include the correct paths for the JAVA
JVM library or DLL.
FIX:
Before starting the Database, set the PATH as follows :
set PATH=%DLC%\jre\bin\hotspot;%PATH%
HTH,
Casper.
syntax
Progress OpenEdge syntax here.
RUN procedureName IN THIS-PROCEDURE /* some handle */.
DEFINE PROCEDURE procedureName.
/* block here */
message 'Hello World' VIEW-AS ALERT-BOX .
END PROCEDURE.
