Hello;
i'm trying to fire a trigger on a progress table.
i'm using access to add a record in this progress table.
*the linking between access and progress is done using Open link odbc.
*in the odbc administrator i put the -trig C:\DLC91D\triggers option
*the file triggers contain a .r of the trigger on table that i'm trying to fire.
*in the data dictionnary\table properties\triggers i put the code of the .r trigger.
when i add a record in access i have a message error saying that the openlink communications line is broken.
can you help me to know if i'm doing right.
Thanks
Thanks
