problem faced during data extraction.
shafee212
with some help from progress talk ,, i have managed to extract data from master tables for only few selected fields..
but only one record in being extracted
my code is as follws
define variable tth As handle no-undo.
define variable qry_hndl as handle no-undo.
define variable tablbuf_hndl as handle no-undo.
define variable tablbuf_hndl2 as handle no-undo.
define variable qry_hndl2 as handle no-undo.
define variable v_tablename as char no-undo .
define variable v_space as char init " " no-undo .
define variable i as integer no-undo .
create query qry_hndl.
create query qry_hndl2.
FOR EACH tttable no-lock:
IF count = 0 THEN DO:
m_line2 = f2.
END.
ELSE
DO:
m_line2 = m_line2 + "," + f2.
END.
ASSIGN count = count + 1.
END.
create temp-table tth.
update v_tablename.
create buffer tablbuf_hndl for table v_tablename.
qry_hndl:set-buffers(tablbuf_hndl).
qry_hndl:query-prepare("for each" + v_space + v_tablename).
qry_hndl:query-open().
tth:CREATE-LIKE(v_tablename).
tth:temp-table-prepare(v_tablename).
tablbuf_hndl2 = tth:DEFAULT-BUFFER-HANDLE .
output to "/home/shafeem/source.csv".
mainloop:
repeat:
qry_hndl:get-next().
if qry_hndl:query-off-end then leave .
do i = 1 to tablbuf_hndl:num-fields:
put unformatted
tablbuf_hndl:buffer-field(i):NAME + ";" +
tablbuf_hndl:buffer-field(i):buffer-value() skip.
end.
tablbuf_hndl2:BUFFER-CREATE.
tablbuf_hndl2:BUFFER-COPY(tablbuf_hndl).
leave.
END.
output close.
qry_hndl2:SET-BUFFERS(tablbuf_hndl2).
qry_hndl2:QUERY-PREPARE("for each" + v_space + v_tablename).
qry_hndl2:QUERY-OPEN().
i = 0 .
output to "/home/shafeem/target.csv".
repeat:
qry_hndl2:get-next().
if qry_hndl2:query-off-end then leave.
DO i = 1 TO tablbuf_hndl2:NUM-FIELDS:
IF LOOKUP( tablbuf_hndl2:BUFFER-FIELD(i):NAME, m_line2 ) > 0 then
PUT UNFORMATTED
tablbuf_hndl2:BUFFER-FIELD(i):NAME + ";" +
tablbuf_hndl2:BUFFER-FIELD(i):BUFFER-VALUE()
SKIP.
END.
leave.
end.
output close.
qry_hndl:query-close().
qry_hndl2:query-close().
delete object qry_hndl.
delete object qry_hndl2.
delete object tablbuf_hndl.
the output i am getting after i did it on pt_mstr is
source.csv :-
pt_part;10-10000
pt_desc1;OASIS(TM) COOLING SYSTEM
pt_desc2;HOME/INDUST
pt_um;ee
pt__qad13;
pt__qad12;0
pt_draw;
pt_prod_line;
pt_group;
pt_part_type;
pt_status;AC
pt_abc;
pt_iss_pol;yes
pt_phantom;no
pt_loc;200
pt__qad01;0
pt__qad02;0
pt_abc_amt;0
pt__qad03;0
pt__qad04;0
pt_avg_int;90
pt__qad05;28/05/92
pt_cyc_int;120
pt_ms;yes
pt_plan_ord;yes
pt_mrp;no
pt_ord_pol;
pt_ord_qty;0
pt_ord_per;7
pt_sfty_stk;0
pt_sfty_time;0
pt_rop;0
pt_buyer;
pt_vend;
pt__qad09;0
pt_pm_code;C
pt_mfg_lead;1
pt_pur_lead;0
pt_insp_rqd;no
pt_insp_lead;0
pt_cum_lead;8
pt_ord_min;0
pt_ord_max;0
pt_ord_mult;0
pt_yield_pct;100
pt__qad16;0
pt_setup;0
pt_setup_ll;0
pt_run_ll;0
pt_run;2
pt_price;3900
pt_xmtl_tl;0
pt_xlbr_tl;0
pt_xbdn_tl;0
pt_xsub_tl;0
pt_xmtl_ll;0
pt_xlbr_ll;0
pt_xbdn_ll;0
pt_xsub_ll;0
pt_xtot_cur;0
pt_xmtl_stdtl;0
pt_xlbr_stdtl;0
pt_xbdn_stdtl;0
pt_xsub_stdtl;0
pt_xtot_std;0
pt_ll_code;-3
pt_abc_qty;0
pt__qad10;0
pt__qad11;0
pt_routing;
pt_lot_ser;S
pt_timefence;0
pt_xmtl_stdll;0
pt_xlbr_stdll;0
pt_xbdn_stdll;0
pt_xsub_stdll;0
pt_rev;
pt__qad15;no
pt__qad17;yes
pt_qc_lead;0
pt_auto_lot;no
pt_assay;0
pt_batch;1
pt_user3;
pt_user1;
pt_user2;
pt_net_wt;50
pt_net_wt_um;KG
pt_size;1
pt_size_um;CM
pt_taxable;no
pt_taxc;
pt_rollup;no
pt_xovh_ll;0
pt_xovh_tl;0
pt_xovh_stdll;0
pt_xovh_stdtl;0
pt_site;10000
pt_shelflife;0
pt_critical;no
pt_sngl_lot;no
pt_upc;
pt_hazard;
pt__chr01;
pt__chr02;
pt__chr03;
pt__chr04;
pt__chr05;
pt__chr06;
pt__chr07;
pt__chr08;
pt__chr09;
pt__chr10;
pt__dec01;0
pt__dec02;0
pt__log01;no
pt__log02;no
pt__qad18;0
pt__qad21;0
pt__qad19;0
pt__qad20;0
pt_length;0
pt_height;0
pt_width;0
pt_dim_um;
pt_pkg_code;
pt_network;
pt_ll_drp;0
pt_fr_class;00000010
pt_spec_hdlg;
pt_bom_code;
pt_loc_type;
pt_transtype;
pt_cover;S
pt_unit_isb;yes
pt_article;
pt_po_site;10000
pt_ship_wt;53
pt_ship_wt_um;KG
pt_formula;no
pt_dea;no
pt__qad26;no
pt__qad22;no
pt__qad25;0
pt__qad24;0
pt__qad23;0
pt_comm_code;
pt_inst_call;yes
pt_sys_type;S
pt_tariff;
pt_origin;
pt_sttr;10
pt_mfg_mtbf;0
pt_mfg_mttr;0
pt_fru;yes
pt_ven_warr;no
pt_svc_group;
pt_svc_type;P
pt_mtbf;9999
pt_mttr;1
pt_isb;yes
pt_pvm_days;365
pt_warr_cd;W-1
pt_mod_date;09/07/08
pt_userid;mfg
pt_pvm_bom;PM10-10000
pt_pvm_route;PM10-10000
pt_pvm_um;
pt_rp_bom;REP10-10000
pt_rp_route;REP10-10000
pt_rp_vendor;
pt_rctpo_status;
pt_rollup_id;
pt_spec_grav;0
pt_joint_type;
pt_mfg_pct;0
pt_pur_pct;0
pt_drp_pct;0
pt_pou_code;
pt_wks_avg;6
pt_wks_max;14
pt_wks_min;2
pt_pick_logic;0
pt_fiscal_class;
pt_dsgn_grp;
pt_drwg_loc;
pt_ecn_rev;
pt_drwg_size;
pt_model;
pt_repairable;yes
pt_rctwo_status;
pt_lot_grp;
pt_rctpo_active;no
pt_rctwo_active;no
pt_break_cat;
pt_fsc_code;ITEMS
pt_trace_active;no
pt_trace_detail;no
pt_pm_mrp;no
pt_ins_call_type;
pt_ins_bom;
pt_ins_route;
pt_promo;pg2
pt_meter_interval;0
pt_meter_um;
pt_wh;yes
pt_btb_type;01
pt_cfg_type;1
pt_app_owner;
pt_op_yield;no
pt_run_seq1;
pt_run_seq2;
pt_atp_enforcement;0
pt_atp_family;no
and target.csv as
pt_um;ee
pt_site;10000
i want to extract data for those fields which are names are stored in tttable.f2 (temp table already created)
only one record is being extracted .
just tell me whether source.csv and target.csv are correct
and can any one could modify my code so that all records present in table is displayed as i have limited knowledge about dynamic queries.
I don't know what you exactly want but there are two things which probably need attention:
First you have the following code:
[COLOR=red]leave.[/COLOR]
within the repeat block, so only 1 iteration will be made.
2nd:
same applies for the second query you run:
repeat:
    do i = 1 to tablbuf_hndl2:num-fields:
        if lookup( tablbuf_hndl2:buffer-field(i):name, m_line2 ) > 0 then
        put unformatted
        tablbuf_hndl2:buffer-field(i):name + ";" +
        tablbuf_hndl2:buffer-field(i):buffer-value()
        skip.
    end.
end.
output close.
Casper.
