Payroll Problem
Chris Kelleher
Administrator
Staff member
Has anyone run into a payroll error while trying to print the current
payroll transactions. The error is "Dist Amount is not equal to the
Gross Pay" ....but the distributed amounts in the current payroll
transactions report for the employees that are referenced add up
exactly to the Gross Pay. ??? Is there something obvious that I am
overlooking?
You might want to check your prparms file to be sure that all of your pay
rate definitions are set to the same decimal size.
Carol Choate
Progress DBA/Programmer
Peg Member #1998062202
