INPUT THROUGH Command using Appservers - no relative path!
Stoods
Using Openedge 10.2B06 - Running on Unix SunOS 5.10
If using the appserver, i make the following call
INPUT THROUGH VALUE("findme")
then the "findme" program won't be found, and an error is returned.
However, if i do the following
INPUT THROUGH VALUE("/progs/findme")
then the "findme" program is found.
How do I get the relative paths working for appservers?
We are already using the working directory on the appserver.
I've also tried altering the propath, but this isn't working.
If I log into unix directly using the appserver login, this is working as the directory is picked up from the .profile
Any ideas? Or do I *have* to use the full path for this command?
Cheers -
Mike
Would this overwrite the original path or add to it?
If it overwrites it - is there anyway just to "add" to it?
If it overwrites wouldn't it simply be solved by %PATH%,CustomPath or CustomPath,%PATH%? (replace %PATH% with $PATH if on *nix).
