I need Help, problemas with Report Builder, rbrun.txt and PROMSGS
ametur
Hi:
I need help, please somebody can tell me where i can obtaina the _printrb.p for progress v9.1a.
I have problemas with the Report Builder.
I am using a net for the applications and the users need to print reports from the server. I'm not using appserver but I'm using netsetup. I have two problems:
rbrun.txt and rbrun.out are saving in the current directory and I have tried to use the database connect parameter with -T
parameter to try to put all these temporary files in a different directory, but it is not working.
I need the current directory like "Read Only" and then I have to put the directory with write permission.
The another one is report builder is putting an error message with the PROMSGS, i believe that has relation with the net, but i don't have the source _printrb.p to customize it.
Please if someone can help me, please answer me soon.
Thanks,
Ametur
:awink:
