How to re-use same code for 2 databases.
Hello All,
Please help me. I want to re-use same code for two database having same structure. I try these steps but not working.
Step 1: Create 2 copies of the sports database with different
physical names, for example testdb1 and testdb2.
Step 2: Connect a session to one of them, using the logical
name x:
pro testdb1 -ld x
Step 3: Create the following program and save it as up.p.
/* up.p */
FIND FIRST x.customer.
UPDATE x.customer.name.
Step 4: Compile and save up.p as follows:
COMPILE up.p SAVE.
Step 5. Exit the Progress editor, and start again, connecting
the 2 databases, the first with logical name aaa, and the
second with logical name bbb.
pro testdb1 -ld aaa testdb2 -ld bbb
Step 6. You can now access both databases with the up.p code as
follows:
CREATE ALIAS x FOR DATABASE aaa.
RUN up.p.
DELETE ALIAS x.
CREATE ALIAS x FOR DATABASE bbb.
RUN up.p.
But this shows an Error of Ambiguity.
Because the Customer table exists in both the database.
Please help me.
Regards
Manoj Kumar
try this out.
lauch procedure editor
pro
/*connect to the first database */
connect -db <> -H<> -S<>
run up.p
disconnect <db>
/*Connect to the second db */
run up.p
disconnect <db>
Arshad
Hello Taqvia,
This code is working fine. but you cann't update any record.
it shows ambiguty error.
RUN up.p.
DELETE ALIAS x.
CONNECT bbb.
RUN up.p.
DISCONNECT bbb.
Also, you need to ensure that this code is in a separate program that doesn't refer to any tables as this may confuse Progress.
The following code works on V9.1E:
DEFINE VARIABLE icount AS INTEGER NO-UNDO EXTENT 2. CONNECT -db db1 -H host1 -S 0000 -N TCP -ld db2.RUN pxxx ("db1",1).RUN pxxx ("db2",2).DISCONNECT db2.DISPLAY icount. PROCEDURE pxxx: DEFINE INPUT PARAMETER pi_cdb AS CHARACTER NO-UNDO. DEFINE INPUT PARAMETER pi_iseq AS INTEGER NO-UNDO. CREATE ALIAS xxx FOR DATABASE VALUE (pi_cdb). RUN xxx.p (OUTPUT icount[pi_iseq]). DELETE ALIAS xxx.END PROCEDURE.
xxx.p:
DEFINE OUTPUT PARAMETER po_icount AS INTEGER NO-UNDO.FOR EACH xxx.systimes WHERE xxx.table.field = "Test" NO-LOCK: ASSIGN po_icount = po_icount + 1.END.
Try the below code it works for me.
/*manoj.p*/
DEF VAR arshad12 AS CHAR.
CONNECT -db c:\arshad .
arshad12= LDBNAME(1).
MESSAGE arshad12.
RUN c:\test1.p arshad12 .
DISCONNECT arshad.
CONNECT -db c:\ars .
arshad12=LDBNAME(1).
RUN c:\test1.p arshad12.
DISCONNECT ars.
/*test1.p*/
/*DEF INPUT PARAMETER taqvi AS CHAR.*/
DEF VAR t1 AS CHAR.
DISABLE TRIGGERS FOR LOAD OF {1}.customer. /*because trigger compiled against sports and i have created it as arshad and ars */
FIND FIRST {1}.customer WHERE NAME = "ManojKumar1" EXCLUSIVE-LOCK NO-ERROR.
IF NOT AVAILABLE {1}.customer THEN
DO:
CREATE {1}.customer.
{1}.customer.NAME ="ManojKumar1".
{1}.customer.cust-num = 240002.
MESSAGE " from first created " .
PAUSE 5.
END.
ELSE
MESSAGE "Taqvi Already Exists".
MESSAGE " {1} ".
FOR FIRST {1}.customer WHERE NAME = "taqvimanoj" NO-LOCK:
MESSAGE {1}.customer.NAME.
MESSAGE " why the hell control not coming".
END.
/*FOR FIRST {1}.customer NO-LOCK:
MESSAGE " from first" .
END.
Regards,
Arshad
