1.HP 3000 series or up type driver with barcode mode can print bar code.
2.the third support, like excel using bar code controler
I want print bar code into transfer form, Can you tell me how to print a character to be bar code? what will i prepare? a special printer? it's better if you can give me a example. thanks .
Hi,as for me, I want to print qrcode 2d barcode. I am totally a green hand on barcode printing field. Any suggestion will be appreciated. Thanks in advance.Try free barcode font? By the way, which barcode type are you trying to generate?
