balasenthilsp
could u help me ?
how to define and use multi dimensional array (extent)
could u help me ?
define variable cName as character extent 5 no-undo.
assign cName[1] = "first extent"
cName[2] = "second extent"
cName[5] = "last extent".
define temp-table mdArray
field x as integer
field y as integer
field z as integer
field payload as decimal
index mdIdx is unique primary x y z
function new_mdArray returns logical ( input x as integer, input y as integer, input z as integer, input p_init as decimal ):
define variable i as integer no-undo.
define variable j as integer no-undo.
define variable k as integer no-undo.
do i = 0 to x:
do j = 0 to y:
do k = 0 to z:
find mdArray exclusive-lock where mdArray.x = i and mdArray.y = j and mdArray.z = k no-error.
if not available mdArray then create mdArray.
assign
mdArray.x = i
mdArray.y = j
mdArray.z = k
mdArray.payload = p_init
end.
end.
end.
return true.
end.
function set_mdArray returns logical ( input x as integer, input y as integer, input z as integer, input p as decimal ):
find mdArray exclusive-lock where mdArray.x = x and mdArray.y = y and mdArray.z = z no-error.
assign
mdArray.x = x
mdArray.y = y
mdArray.z = z
mdArray.payload = p
return true.
end.
function get_mdArray returns decimal ( input x as integer, input y as integer, input z as integer ):
find mdArray no-lock where mdArray.x = x and mdArray.y = y and mdArray.z = x no-error.
return ( if available mdArray then mdArray.payload else ? ).
end.
set_mdArray( 0, 0, 0, 99.99 ).
display get_mdArray( 0, 0, 0 ).
