How to build a variable holding JSON data in a class method?
mcraig.brs
Progress 10.2b on Red Hat Linux
I have 2 questions that are related about Streams and JSON.
1. How can I take a temp-table and convert it to a JSON string and place that string in a variable that can be passed through a METHOD of a class.
2. How can I take a temp-table and export it to a file using class Method.
I have read through the JSON manual, and I do not see how to do these in an object oreinted way. I keep getting the error that I cannot have a stream in a function or method.
I figure this is something simple I just don't know where to look.
Any help is apreciated
Matt
You can use the WRITE-JSON method on the buffer-handle to write the output to a longchar:
DEFINE TEMP-TABLE tt
   FIELD cc AS CHAR.
DEF VAR lcc AS LONGCHAR.
CREATE tt. tt.cc = "hello world".
TEMP-TABLE tt:DEFAULT-BUFFER-HANDLE:WRITE-JSON( "longchar", lcc ).
MESSAGE STRING( lcc ) VIEW-AS ALERT-BOX.
Static streams are, just as static temp-tables, defined at program level, so cannot be scoped locally. You can however create a dynamic stream (see CREATE STREAM).
