F fabio_msx New Member Jan 2, 2008 #1 I created a simple table with four fields. I would like to make an application to create, read, update and delete records, with a record navigation bar. (CRUD) Someone can help me posting a simple program that does this? Thanks. Fabio
P parul Member Jan 3, 2008 #2 http://www.psdn.com/library/entry!default.jspa?categoryID=464&externalID=1928&fromSearchPage=true Try the ABL handbook, there should be enough material to get you started. And http://www.psdn.com/library/entry!default.jspa?categoryID=1171&externalID=402&fromSearchPage=true For smart objects. -Parul.
