Hi,
Being reasonably new to Progress, and being one of those people who picks all the slack, I have to look after our DRP server for the next 3 - 4 weeks. My issue is that I have 2 DRP databases which have been corrupted, and I have had to restore from production copies. No big deal. Where my issues start is the rfutil roll foward of AI files.
The log file shows output such as:
[FONT=r_ansi]
09:53:33 RFUTIL 0: Expected ai file number 1 but file specified is 1766 in sequ
ence. (8019)
09:53:33 RFUTIL 0: ** The database was last changed Mon Dec 12 23:31:33 2005. (
831)
09:53:33 RFUTIL 0: ** The after-image file expected Fri Dec 9 22:00:44 2005. (
832)
09:53:33 RFUTIL 0: ** Those dates don't match, so you have the wrong copy of on
e of them. (833)
09:53:33 RFUTIL 0: roll forward open /bkp/prod/cfp/ai/mfg.a6.20051209_233200 er
ror: -1
09:53:33 RFUTIL 0: rfutil -C roll forward session end. (334)
mfg
mfg.a6.20051209_233200 FAILED - Return Code 2
APPLIED mfg.a6.20051209_233200 at 13 Dec 2005 09:53 FAILED - PLEASE CHECK
There is some confusion around whether I should be truncating the BI file prior to the roll beginning...however if I do it, or don't do it, the messages are the same...
I know i'm missing something simple, can you guru's help?
[/FONT]
[FONT=r_ansi]
ence. (8019)
831)
832)
e of them. (833)
ror: -1
mfg
[/FONT]
