jumbosafari
hi. i'm in need of some assistance.
as well, i'm a newb to progress.
specs:
progress 9.1c
mysql 5 (not installed on linux system)
linux redhat (no gui)
i would like to dump a progress db to mysql, any ideas?
there is a problem, i don't have a login or password to the progress db.
i currently have the progress db 9.1c installed on a redhat machine.
i'm looking for a way to end up with a csv or sql dump.
is it possible to get into the progress db admin tool without login creds?
as well i have access to all files of the entire linux filesystem.
i do have root access to the redhat linux installation
possibly this can achieved from the command line using a progress db command?
showcfg returned:
product name: workgroup db
user limit: 15
serial num: 003335765
control numbers: sffff-sdfds-sdfsf
version number: 9.1c
machine class: kb
port number: 38
result for :
$DLC/bin/pro databasename
--this version of progress requires a start up procedure.(495)
result for :
$DLC/bin/mpro databasename
--error. there is no server for database.(1423)
sometimes i also get another error.
--standard input and output are on different terminals. (360)
any ideas?
any help would be much appreciated.
thanks.
specs:
progress 9.1c
showcfg returned:
user limit: 15
machine class: kb
port number: 38
result for :
result for :
any ideas?
thanks.
