Help Box
Jenie888
:daisy:
Hey,
I was wonder if anyone had any info on how to impliment a Help into a progress program. A former employee, at where I work, created a help directory and on the press of F1 a help box appeared displaying our user manual, just like Progresses Help. Unfortunatly i am baffled on how he implimented it. I have been diggong for a while and I am still confused...
If anyone has any info on this, it would be greatly approcated!
Thanks,
Jenie:cool:
Help file generation programme
Search your computer for a file called hcw.exe and a file called hcrtf.exe. These programmes can be used to design your help system.
Incase your stick stuck
In case you havent got any further try this link to my website http://www.innov-8.de/help2.htm . There is an example of using OCX to add the help files into your programmes. Just click on the fields and press F1!
If you need further help or an expaination from anything just send me a mail.
HCW.exe or HCRTF.exe
Those miles mentioned (hcw.exe and hcrtf.exe were not found. I'm going to look into that last post you submitted. I'll let you know.
Thanks!
;p
