C
CABI
OpenEdge 11.3.0 (appbuilder technology). Server is Windows 2008 R2 (64bit) holding the databases, appservers and application code. The clients are Windows 2007 machines (10% 64bit, 90% 32bit) using 32bit OpenEdge and run the code from their PCs via a .pf file (basic client server set-up code written from 1995 onwards). 1) Are there any issues that I may not have noticed if I compile the application code on the server compared with compiling from my development PC (Windows 7,64bit, running 32bit OpenEdge ? 2) ADM1 SmartObjects won't compile on the server as the required ..\src\adm\ folders do not have code files. Can I copy these folders from my development PC onto the server' and compile the Smartobject based .w files from the server? (GUI screens on the server don't use Smartobjects only client PCs use this functionality). So far nothing major has turned up, just one or two minor oddities that spring up intermittently.
