C
cverbiest
In a discussion whether to use a property or a variable, I expected that a variable would be faster than a property as it doesn't have the overhead of setters/getters so I ran a test comparing assigning a variable vs a property. Turns out that as long as no setters are involved a property is the fastest and a local variable is the slowest. Once the setter is added a property is much slower as expected. Is this a known difference ? Before this test I assumed a local variable to be the fastest of them all. Did I make a mistake in my test ? lqqqqqqqq Information qqqqqqqqqk x 106 :Local var x x 85 :global var x x 55
roperty x x 522
roperty empty set x x 559
roperty set x x qqqqqqqqqqqqqqqqqqqqqqqqqqqq x Related thread Property or Variable ? class test: &scoped-define testcount 100000 define variable myVar as char no-undo. define private property myProp as char no-undo get. set. define private property mySetPropNocode as char no-undo get. set (input istring as char): end set. define private property mySetProp as char no-undo get. set (input istring as char): mySetProp = istring. end set. constructor test(): def var i as int no-undo. def var localVar as char. define variable Results as character no-undo. etime(yes). do i = 1 to {&testcount}: localVar = string(i). end. results = subst("&1&2 :Local var ~n", results, string(etime, "zzzzz9")). etime(yes). do i = 1 to {&testcount}: myVar = string(i). end. results = subst("&1&2 :global var ~n", results, string(etime, "zzzzz9")). etime(yes). do i = 1 to {&testcount}: myProp = string(i). end. results = subst("&1&2
roperty ~n", results, string(etime, "zzzzz9")). etime(yes). do i = 1 to {&testcount}: mySetPropNoCode = string(i). end. results = subst("&1&2
roperty empty set ~n", results, string(etime, "zzzzz9")). etime(yes). do i = 1 to {&testcount}: mySetProp = string(i). end. results = subst("&1&2
roperty set ~n", results, string(etime, "zzzzz9")). message Results view-as alert-box information buttons ok. end. end class.
