Dileep Dasa
If I understood correctly, you are looking for a method to read an XML into a dataset. This is possible with READ-XML() method. Here is an example: DEFINE VARIABLE cSourceType AS CHARACTER NO-UNDO. DEFINE VARIABLE cReadMode AS CHARACTER NO-UNDO. DEFINE VARIABLE lOverrideDefaultMapping AS LOGICAL NO-UNDO. DEFINE VARIABLE cFile AS CHARACTER NO-UNDO. DEFINE VARIABLE cSchemaLocation AS CHARACTER NO-UNDO. DEFINE VARIABLE cFieldTypeMapping AS CHARACTER NO-UNDO. DEFINE VARIABLE cVerifySchemaMode AS CHARACTER NO-UNDO. DEFINE VARIABLE lRetOK AS LOGICAL NO-UNDO. DEFINE VARIABLE hDSet AS HANDLE NO-UNDO. CREATE DATASET hDSet. ASSIGN cSourceType = "file" cFile = "dset.xml" cReadMode = "empty" cSchemaLocation = "cust-ord-inv.xsd" lOverrideDefaultMapping = ? cFieldTypeMapping = ? cVerifySchemaMode = ?. lRetOK = hDSet:READ-XML(cSourceType, cFile, cReadMode, cSchemaLocation, lOverrideDefaultMapping, cFieldTypeMapping, cVerifySchemaMode).
