Forum Post: Re: Way To Read A Text File And Load
  • Thread starter Thread starter Manooj Murali
Manooj Murali
Unfortunately, Rollbase cannot read txt files like these. You will have to convert them into a csv, xls/xlsx and use the import feature to import the records. It has to be structured so that the first row has the column names that you can use to map to Rollbase object's fields & the following lines will have the data that needs to go into each record. Each line after the first line will be used to create one record each in Rollbase.
