O
Orchid Corpin
Hi yellek, Here are some answer to the following questions: 1. Not sure for this, basically the Tab type = Web is an iframe of a website that you specified during creation, you can embed any site or portal as long as they are accessible through your browser. 2. Yes, Checkbox type of field in Rollbase is returning a boolean value. 3. Yes, password type of fields are all masked characters. 4. Yes, if you created multiple workflow processes you can change the saved record's workflow process as it will be display as a picklist type which you can switch values through it. Hope this may help. Regards, Orchid
