Godfrey Sorita
Yes, it is much clearer now. Did you use the original ID of the view in the #LOOP_BEGIN token? All related records are also displayed (no filter) when I use an incorrect view ID on the #LOOP_BEGIN token. Also, it's a good practice to use the Template Helper in determining the tokens on your html template. I believe the template should be written like: {!#LOOP_BEGIN.R217338#217305} {!R217338.principal} {!R217338.project} {!R217338.workorder_number} {!R217338.location} {!R217338.start} {!R217338.hours} {!#LOOP_END.R217338}
