Forum Post: RE: Using the comdlg32.dll in a 64bit progress client
  • Thread starter Thread starter PeterWokke
P
PeterWokke
Matt, Thank you for your info. I understand the principal of your statement. . Does it main that the SET-SIZE should be larger then 76. And that the numbers in the PUT-LONGs and PUT-SHORT need to be adjusted. I see they cummulate by 4 for a PUT-LONG and by2 for a PUT-SHORT. For 64bit 8bytes I should increase by 8 for the PUT-LONG. What should be the increase for the PUT-SHORT, Still 2 or 4. Thank you kindly to confirm the right answer, Peter
