Forum Post: RE: transparent background for popup
  • Thread starter Thread starter Ricardo Perdigao
Ricardo Perdigao
Hi Meyrick, Please check the Sample Project I shared with you with a solution. Areas changed: - Created a CSS file called Transparent - Created a JavaScript file called Transparent Code for the CSS: .ui-dialog-background { opacity: 0.5; display: block !important; -webkit-transition: opacity 0.5s ease-in; } .ui-dialog-background.pop.in { opacity: 1; -webkit-transition: opacity 0.5s ease-in; } .ui-dialog { min-height: 80% !important; background: transparent !important; z-index: 3000; } Code for the JavaScript: $('div[data-role="dialog"]').live('pagebeforeshow', function(e, ui) { ui.prevPage.addClass("ui-dialog-background "); }); $('div[data-role="dialog"]').live('pagehide', function(e, ui) { $(".ui-dialog-background ").removeClass("ui-dialog-background "); }); Please let us know if this helped and if you have further questions. Regards, Ricardo
