Forum Post: RE: Tomcat fails to write in exceptions.log even after using Progress KBase: P23209
  • Thread starter Thread starter Libor Laubacher
L
Libor Laubacher
$WRKDIR = /test/apps/dlcwrk/ does not set the variable WRKDIR = /test/apps/dlcwrk/ does or rather WRKDIR = /test/apps/dlcwrk ; export WRKDIR just to be safe. Also there is no such "-d64" into JAVA_OPTS in setenv.sh. Do you want us to add it explicitly ? First please fix setting the WRKDIR, and retest. you can put echo $WRKDIR in the startup.sh to see if it's set properly Once the variable is properly set and it still does not solve the problem, then please yes, add the "-d64" into JAVA_OPTS.
