Forum Post: Re: Tomcat fails to write in exceptions.log even after using Progress KBase: P23209
  • Thread starter Thread starter awadheshmca12
awadheshmca12
Hi Libor, We have set the Progress variable in startup.sh of the tomcat. As per the Progress KBase. $WRKDIR = /test/apps/dlcwrk/ The OS is 64 bit. Also there is no such "-d64" into JAVA_OPTS in setenv.sh. Do you want us to add it explicitly ? Regards, Awadhesh --------------------------------------------- Awadhesh Kumar aeq@qad.com Global Technical Customer Service QAD INDIA PVT LTD. www.qad.com/erp/support http://www.qad.com/erp QAD - Our Passion. Your Advantage. On Tue, Jul 8, 2014 at 7:23 PM, Awadhesh Kumar aeq@qad.com wrote: Hi Libor, the current permission to the log is 644 but it failed to write to that log. -rw-r--r-- 1 abc xyz 4840 Jun 30 11:24 /test/apps/tomcat/temp/exceptions.log The startup.sh is run by abc only the owner. The owner only starts it. OS: OS Version: Red Hat Enterprise Linux Server release 5.10 (Tikanga) Java: /usr/java/jdk1.5.0_21/bin/java java version "1.5.0_21" Java(TM) 2 Runtime Environment, Standard Edition (build 1.5.0_21-b01) Java HotSpot(TM) 64-Bit Server VM (build 1.5.0_21-b01, mixed mode) Progress:OpenEdge Release 10.2B04 DLC: /test/apps/dlc WRKDIR: /test/apps/dlcwrk OEM: /test/apps/oemgmt OEMWRKDIR: /test/apps/wrk_oemgmt Let us know if you need more info. Regards, Awadhesh
