B
Brian K. Maher
Hi James, You could try making a copy of the $DLC\bin\progress.ini file, edit the file and add "NoSplash=Yes" to the [Startup] section then save it. Once that is done just use the $DLC\bin\ini2reg.exe utility and point it to your new progress.ini file then click the "Translate" button. This will update the registry with the contents of the progress.ini file. Sincerely, Brian Maher (Technical Support)
