Forum Post: RE: System.Xml.XmlException: Mising root element
  • Thread starter Thread starter Swathi Yellavaram
Swathi Yellavaram
Hi Octavio, Can you please let us know AVM settings for the oetap2 project? If project is using shared AVM then assemblies.xml file will be stored in Workspace Location \.sharedavm. If project specific AVM is used then assemblies.xml will be under project node. If the file is not under project node then you need to mention assemblies.xml file path in project properties by unchecking use default. Place .dll files in same place where your assemblies.xml file is existing and then try adding assemblies. Thanks, Swathi.
