Forum Post: RE: System Error (Syntax Error in formula)
  • Thread starter Thread starter shkumar
shkumar
Hi Kim , thanks for providing your observations on this issue . I would like to suggest you to verify the below points 1)check if object or Record have any dependencies . 2) Enable audit trail in object definition , to keep track of the transactions being performed on that object . This may give us some useful information 3) See if there is any trigger running on any record on creation and using formula fields present in the record ( both transaction might be running parallely , resulting this issue.. 4) If you are using Custom triggers , please check for the syntax errors in that script. thanks, sharavan
