Forum Post: RE: Slow connection between AIA and appserver
  • Thread starter Thread starter bart.syryn
B
bart.syryn
hi, Thanks for the reply. Can you help me how I can check if java process uses ipv4 or ipv6 protocol ? There's nothing defined in the hosts-file. Checked 'proenv nsman -i NS1 -query' and everything seems ok. The NS connects not with localhost, but the ip-adress of the server. But if I just tried to connect to AIA and appserver with localhost or the internal IP-adres or with 127.0.0.1, than the result is always the same, between 10 and 15sec to connect to the appserver. netstat -ab : i don't see any entry on port 5162.... I really don't known what could be the issue here. Kind regards, Bart Syryn
