Forum Post: Re: Scope of DISABLE TRIGGERS FOR LOAD
  • Thread starter Thread starter Marian Edu
Marian Edu
allow-replication can be used to let the replication ones alone... On 04.11.2014 17:53, gabriel.lucaciu wrote: From: gabriel.lucaciu Post: RE: Scope of DISABLE TRIGGERS FOR LOAD Posted in: Forum Link: http://community.progress.com/community_groups/openedge_development/f/19/p/14069/50400.aspx#50400 As an update on your first question on "the scope of the disable triggers for load": Disabling triggers for LOAD disables all triggers associated with the CREATE, WRITE, REPLICATION-CREATE, REPLICATION-WRITE, REPLICATION-DELETE, and ASSIGN events for the named table. -- You were sent this email because you opted to receive email notifications when someone created a new thread. To unsubscribe from: - ...only this thread, disable notifications at http://community.progress.com/community_groups/openedge_development/f/19/p/14069/50400.aspx#50400. - ...all email notifications from Progress Community, navigate to "Settings", click on the "Email" tab, then under the "Email Configuration" section, set Send Notifications to "No". -- m.edu keep it simple http://www.ganimede.ro http://ro.linkedin.com/in/marianedu medu@ganimede.ro mobile: +40 740 036 212 skype: marian.edu
