Forum Post: RE: Rollbase Mobile: login problems after logging out
  • Thread starter Thread starter Anil Kumar
Anil Kumar
Hi Harrie, There is an issue in the default Backbutton behavior added for the mobile page. The events added for the Backbuon are not honored and always it moves to previous page even though we have some custom actions added for the specific button (say adding an alert statement). It is observed that the problem is with the libraries version possessed by mobile application. Currently the apps are pointed to 3.0 version and the fix is available 3.1 version. I have reported an issue for this problem. Note : The libraries version upgrade will happen as part of the Rollbase Mobile 3.1 release which is scheduled for Dec 2014. Thanks and Regards, Anil Kumar. From: Harrie Kuijper [mailto:bounce-hkuijper@community.progress.com] Sent: Tuesday, November 04, 2014 6:13 PM To: TU.Rollbase@community.progress.com Subject: RE: [Technical Users - Rollbase] Rollbase Mobile: login problems after logging out RE: Rollbase Mobile: login problems after logging out Reply by Harrie Kuijper Hi Anil, Thanks for your answer. Adding the MyLogoutButton doesn't solve my problem. The logout button shown in the app already works well, but I'm facing the issue when I use the physical back button of Android. Since the back button is a common feature in Android, a lot of Android users will use it and therefore run into this error. The error is reproducible in the emulator by pressing backspace in DetailPage. Like I said in my first post, I tried the following: imagizer.imageshack.us/.../CLR0x8.png But it didn't work out. Stop receiving emails on this subject. Flag this post as spam/abuse.
