Forum Post: Re: Rollbase Error Components/errorpage.jsp?errormsg=read+timed+out
  • Thread starter Thread starter Jorrit
Jorrit
Hi, Karthikeyan i was to early the error came when we upload an image larger than 56 kb or so. the problem solved when we set the psc.as.http.connectiontimeout frome 20000 ms to 40000 ms. a answer to your questions: - Installation is new (no update). - Webserver and db server on the same machine. - when i do the same on the localhost via Terminalsever it is fast. - remote on the master server i have the same problem. - we use the database that comes with the installer. OE 11.5 Answer to the questions of Mani: 1. What is the size of image that you are trying to upload? 405 kb (.png) 3. If Private cloud, what is the "MaxFileSizeKB" that is set in shared.properties file (..\...\Progress\Rollbase\Pas_Instance\rollbase\config) 5012 kb 4. What is the actual field type? (Image or file upload field)? field type is Image but with the document upload the same problem 5. Is this issue seen for all files that you are trying to upload? yes thanks in advance. Jorrit
