Forum Post: RE: Recycle Bin
  • Thread starter Thread starter Fil
F
Fil
I think the features as describe in those posts are appropriate - some sort of filtering similar to a view so you can search the recycle bin and selectively restore/purge records. This would also need to extend to being able to select more than 20 records at a time like you can on normal object views as well. The other major feature is major improvements on purging efficiencies. When I try and empty the recycle bin with more than around 200,000 records, the system has a major heart attack, sometimes crashes, with memory errors, and purges nothing. Purging the recycle bin 20 at a time for that number of total records is not fun or practical. In this instance, I had 345,000 records. To answer my first question in my opening post, I've gone directly into the database engine (MySQL) deleted them from the RB_DELETED_OBJS table and it seems to have coped, although I think I should've stopped Rollbase first. Is there anything else we should do after having emptied the table from the database? F
