Forum Post: RE: Radio Buttions field updation is not working
  • Thread starter Thread starter Godfrey Sorita
Godfrey Sorita
Hi Sudhakar, Your triggers are not updating because the first if statement will always return false. When the token is parsed in Rollbase, it is treated as string because of the single quotes. Please remove the single quote so that it would be treated as an integer. Also, the succeeding if statements uses "=". You should use "==" when comparing values in JavaScript. Regards, Godfrey
