Forum Post: RE: Progress openedge pacific rollbase for mobile
  • Thread starter Thread starter Anil Kumar
Anil Kumar
Hi Pradeep, If I understand your question correctly you want to use OpenEdge 11.3 database as your backend for the Rollbase Mobile application i.e., all the data from the Rollbase Mobile app should be placed in the OpenEdge database. If my assumption is right then you can install Rollbase Private cloud (3.0.2) using OpenEdge database (by default ships with OpenEdge 11.3.2 version) or MySQL Server, create few objects in Rollbase using ‘External Tables’ model (such that the objects are available in Rollbase natively) and develop a mobile application using the same objects. The other case is using the OpenEdge service objects, through this mechanism you can create an object in Rollbase using the catalog file (.json) generated in OpenEdge and with those objects one can create a mobile application by exporting specific views to be part of mobile app. This mechanism works with OpenEdge Appserver via the REST (or Mobile) services. Design Time : .json (catalog file) - RB Object creation - Create mobile app using those objects Runtime : Mobile Emulator - RB Object - OpenEdge Appserver - OE database. Hope this helps. Thanks and Regards, Anil Kumar. From: Pradeep143 [mailto:bounce-Pradeep143@community.progress.com] Sent: Thursday, September 25, 2014 2:30 PM To: TU.Rollbase@community.progress.com Subject: [Technical Users - Rollbase] Progress openedge pacific rollbase for mobile Progress openedge pacific rollbase for mobile Thread created by Pradeep143 Hi All, Can any one tell me the steps to connect an external database to my mobile app. Database is in 11.3 version of progress. Stop receiving emails on this subject. Flag this post as spam/abuse.
