Forum Post: RE: Prodataset issue
  • Thread starter Thread starter gryphon
gryphon
Hi I think your problem lies with your query….. its defined for customer and order DEFINE QUERY qOrder FOR CUSTOMER, ORDER . Your Temp tables are like order and order line…. So your query should contain both these tables. DEFINE TEMP-TABLE ttOrder LIKE order . DEFINE TEMP-TABLE ttOrderLine LIKE orderline FIELD ProductRef AS CHAR FIELD ProductDescription AS CHAR. Then your datasource needs to contain keys for both order and orderline tables. DEFINE DATA-SOURCE srcOrderLine FOR ORDERLINE KEYS (ORDER_NUMBER), PRODUCT KEYS (PRODUCT_NUMBER). Then your query prepare should contain the tables referenced in your table definitions… Try doing it this way… the following code is take from the documentation and might not work as it is. DEFINE TEMP-TABLE ttOrder LIKE Order FIELD OrderTotal AS DECIMAL FIELD CustName LIKE Customer.Name FIELD RepName LIKE SalesRep.RepName. DEFINE TEMP-TABLE ttOline LIKE OrderLine. DEFINE DATASET dsOrder FOR ttOrder, ttOline DATA-RELATION OrderLine FOR ttOrder, ttOline RELATION-FIELDS (OrderNum, OrderNum). DEFINE QUERY qOrder FOR Order, OrderLine. DEFINE DATA-SOURCE srcOrder FOR QUERY qOrder. QUERY qOrder:QUERY-PREPARE("FOR EACH Order WHERE Order.OrderNum = 1,EACH orderline OF order"). BUFFER ttOrder:ATTACH-DATA-SOURCE(DATA-SOURCE srcOrder:HANDLE,"Customer.Name,CustName"). DATASET dsOrder:FILL(). BUFFER ttOrder:DETACH-DATA-SOURCE(). Elsworth Burmeister Developer - Managed Services Cell: +27 83 777 3072 Email: eburmeister@elcb.co.za ELCB Information Services (Pty) Ltd Customer Service Email elcb@elcb.co.za · www.elcb.co.za E A S T L O N D O N Tel: +27(43) 704 0700 Fax: +27(43) 704 0701 J O H A N N E S B U R G Tel: +27(11) 879 6179 Fax: +27(11) 454 0384 P O R T E L I Z A B E T H Tel: +27(41) 373 0529 Fax: +27(86) 650 0135 Disclaimer From: oedev [mailto:bounce-oedev@community.progress.com] Sent: 23 February 2015 05:52 PM To: TU.OE.Development@community.progress.com Subject: [Technical Users - OE Development] Prodataset issue Prodataset issue Thread created by oedev Taking the following example code, I can an error when running "Must assign a user query to a data-source that is a join before filling" (11980) I've tried changing the data source srcOrderLine to a query as well (on the tables ORDER_LINE and PRODUCT), but I then get all the orderline records in the database. Must be doing something obvious and simple wrong?! DEFINE TEMP-TABLE ttOrder LIKE order. DEFINE TEMP-TABLE ttOrderLine LIKE orderline FIELD ProductRef AS CHAR FIELD ProductDescription AS CHAR. DEFINE DATASET dsOrder FOR ttOrder, ttOrderLine DATA-RELATION OrderOrderLine FOR ttOrder, ttOrderLine RELATION-FIELDS (ttOrder.order_number, ttOrderLine.order_number). DEFINE QUERY qOrder FOR CUSTOMER, ORDER. DEFINE DATA-SOURCE srcOrder FOR QUERY qOrder. DEFINE DATA-SOURCE srcOrderLine FOR ORDERLINE KEYS (ORDER_NUMBER), PRODUCT KEYS (PRODUCT_NUMBER). QUERY qOrder:QUERY-PREPARE("FOR EACH CUSTOMER WHERE CUSTOMER_REFERENCE = '1111111' NO-LOCK, " + "LAST ORDER OF CUSTOMER NO-LOCK"). BUFFER ttOrder:ATTACH-DATA-SOURCE(DATA-SOURCE srcOrder:HANDLE). BUFFER ttOrderLine:ATTACH-DATA-SOURCE(DATA-SOURCE srcOrderLine:HANDLE). DATASET dsOrder:FILL(). Stop receiving emails on this subject. Flag this post as spam/abuse.
