andrew.may
Re-running SP1 solved Robin's problem. We hit a nasty gotcha on a colleague's machine though, which meant that SP1 silently corrupted his PDSOE installation... He had at some point in the past (accidentally) updated his PDSOE Eclipse installation to 3.7.2 (probably while installing a v3.7.2 compatible version of the JDT plugin). This (unsupported) configuration generally works & so no alarms were raised at the time. The problem was that the OE11.3 SP1 installer successfully removed the OE11.3 Eclipse plugins, but silently failed to install the OE11.3.1 version of the OE Eclipse plugins. (I'm guessing that this is because IntegrateArchitect.bat refuses to install into 3.7.2 Eclipse installations). This had the net effect of making Eclipse refuse to startup, with a log file entry reading "java.lang.IllegalStateException: Unable to acquire application service. Ensure that the org.eclipse.core.runtime bundle is resolved and started (see config.ini)." We're now uninstalling & reinstalling 11.3 + 11.3.1 to correct the issue.
