Forum Post: RE: Problems with Infragistics controls in OE11.3.1
  • Thread starter Thread starter Anil Kumar
Anil Kumar
Hi RJPowell, I hope you are also experiencing this problem in all the workspaces (fresh workspace)? One possible reason could be because of unavailability of .Net framework. Can you please check if the .Net framework 4.0 got installed properly. Hope this helps. Thanks and Regards, Anil Kumar. From: RJPowell [mailto:bounce-RJPowell@community.progress.com] Sent: Wednesday, September 03, 2014 5:51 PM To: TU.OE.Development@community.progress.com Subject: [Technical Users - OE Development] Problems with Infragistics controls in OE11.3.1 Problems with Infragistics controls in OE11.3.1 Thread created by RJPowell Afternoon, I am having issues getting the Infragistics controls installed on my machine to be correctly recognised. They were installed by adding the OE Ultra Controls to an existing OE11.3.1 installation, installed under the same user as the original installation. They appear correctly under the Referenced Assemblies in the existing Eclipse project which uses them, and can be opened up in the Class Browser. All of the dlls appear to be present and registered to the correct locations as compared to a working installation on another machine. However, nothing will recognise them as being present. Within Eclipse the project shows errors saying that it cannot find the interface or class wherever an Infragistics control is referenced. Attempting to compile outside of Eclipse using the command line also fails for the same reasons, so we are confident it is not a configuration issue within Eclipse itself. If anyone has encountered this or similar, any help you could provide would be much appreciated Stop receiving emails on this subject. Flag this post as spam/abuse.
