ske
Tjerk Coomans: Another suggestion would be to use PDSOE instead of studio. It's fully integrated from 11.2. You still have the old designer but can also use all new capabilities of PDSOE. Someone suggested te above as the final answer. But to me it seems like the least relevant of all the suggestions given, sorry. To clarify: When I said "Devloper Studio", which is the name used in the program menu and in the start banner, I meant the Eclipse based integrated development environment. I think that is the same Tjerk meant when he said "PDSOE". As I said from the start, the symtoms are the same there. I suppose the problem is linked to the Arcade Showroom machine using 64 bit Progress, while most OCX controls are 32 bit only, like som other people suggested. Thanks for all those answers, and for the help finding out which kind was installed, including the other reply from Tjerk, and to Dileep Dasa for logging an issue regarding the grey section listing window. Still wondering though why only a 64 bit Showroom machine is provided (unlike the Showroom machines for previous versions and with no information that it is 64 bit), and also why this restriction for OCX controls is not also documented right away in the AppBuilder manual (and not only somewhere else) where they are mentioned in a way like they should always be available.
