K
Karthikeyan Bhaskaran
I tested this against 11.3.2. I was able to see the scheduled operation kicking in. Can you check the behavior after creating a single instance of this process? If not, start again, from the beginning (summarizing all actions from current posts). 1. Check if DB is started properly. 2. Check if all servers are running - check some pages on BPM Portal, for example. 3. Install this process once again. 4. Create an instance of this process. Check the behavior.
