Forum Post: RE: Problem with BPM Events scheduled: Create Process Instance
  • Thread starter Thread starter Jawahar Surapaneni
Jawahar Surapaneni
Hi, Can you please share the following additional details... Are you using OEBPM 11.3 or 11.3.2? and also what kind of action you are performing apart from Creating a Process Instance using the Schedule rule I have created a sample project which performs the following actions... Create a Process Instance Install Process Template SendEmail Alerts I was able to invoke all the above mentioned four actions successfully. If possible, can you please share your project, so that we will analyze the same and get back to you. Regards, Jawahar.
