Anil Kumar
Hi Joule, There seem to be a code generation issue where in JSDO code generation is not honoring the new integration names at few places. i.e., I could see most of the places the name got changed to crm_lead12 but still few places it possess the earlier name which is ‘crm – lead1’ which is causing the app not to load the mobile pages. As a workaround I could think of following scenarios : 1) Remove all the exported views from the mobile application, save mobile app and export all the views again back mobile application (assuming none of the object integration names should have hyphen) or 2) Please try creating a new mobile application (with modified integration names) by exporting required views and see if this solves the current problem. Note : There are some problems in loading elements which possess hyphen (-) and as a result Rollbase is by default generates all hyphens with underscores in integration names. However, Rollbase currently allows user to customize the integration names where in hyphens are allowed which resulted in above mentioned problems. I will report an issue for Rollbase such that integration names should not allow hyphens even when user tries to provide them explicitly. Hope this helps. Thanks and Regards, Anil Kumar. From: Joule [mailto:bounce-joule@community.progress.com] Sent: Wednesday, November 05, 2014 12:16 PM To: TU.Rollbase@community.progress.com Subject: RE: [Technical Users - Rollbase] Problem loading mobile app onto browsers for testing RE: Problem loading mobile app onto browsers for testing Reply by Joule Hi Anil, I did update the Integration Name to "xx_xx" format via Object Definition page and also performed Sync Metadata but to no avail. The test output service.js file still shows 'crm-lead1'. Btw, my new Integration Name is "crm_lead12". The "12" digit was auto-filled in by RB. Pages and Views using "crm_lead12" Object are all working properly. Stop receiving emails on this subject. Flag this post as spam/abuse.
