Anil Kumar
Hi araqiel, Starting from Rollbase 3.0.2, Progress Rollbase uses Pacific Appserver for hosting the Rollbase application WAR files instead of using the vanilla tomcat server. The Pacific Appserver hierarchy is designed as such it will have a root webserver which is pas and we will have multiple instances which can be increased basing on the requirements. By default the Rollbase application WAR files are placed in the default instance namely pas_instance. Hope this helps. Thanks and Regards, Anil Kumar. From: araqiel [mailto:bounce-araqiel@community.progress.com] Sent: Monday, September 01, 2014 7:18 PM To: TU.Rollbase@community.progress.com Subject: [Technical Users - Rollbase] Private Cloud 3.0 : Difference between pas - Pas_Instance Private Cloud 3.0 : Difference between pas - Pas_Instance Thread created by araqiel Hi, I''ve installed Private Cloud 3.0. As version 2, the folders trees have changed. And now there have two strange folders. I don't understand the difference between Rollbase/pas & Rollbase/Pas_Instance. Could you explain them ? Thanks, Stop receiving emails on this subject. Flag this post as spam/abuse.
