Forum Post: RE: Possible bug or timing issue with triggers
  • Thread starter Thread starter Godfrey Sorita
Godfrey Sorita
Please check for update APIs on the parent object which updates the child records. When using setFieldValue outside a related loop to update a child record, it only updates the first record on the grid control. This might be a possible culprit for this issue. I recommend logging a support case for this question/problem so a Progress TSE may assist you debugging and pointing the cause of the error.
