Richard Banville
Is it possible that there is a difference between startup parameters for the 2 runs – most notably the –q parameter? Or that the PROPATH is different between the 2 runs? With so many statx() system calls, I would think that the ABL’s PVM is validating .p or .r location more often. From: Rob Fitzpatrick [mailto:bounce-robfsit@community.progress.com] Sent: Tuesday, December 09, 2014 8:53 PM To: TU.OE.RDBMS@community.progress.com Subject: RE: [Technical Users - OE RDBMS] Performace degradation between / /Power8 RE: Performace degradation between / /Power8 Reply by Rob Fitzpatrick The high number of stat calls for non-existent files sounds like propath searching. It could be normal for your application. It would be helpful to compare those numbers against prod, or a prod-like environment. Can you see the file names in your trace? If so, is it a lot of files with .p or .r extensions? Stop receiving emails on this subject. Flag this post as spam/abuse.
